daArry
londaaan
« on: June 29, 2004, 11:31:30 pm » |
Hey (NYD in particular :grin:) Is -this- on the right track (only showing 3 chans) or do I only need 1 pair of output resistors for all chans combined? - tis just the 1 pair init.... :roll: nice :thumb: d
Ethan
In my mind: Jamaica
Administrator
Jammin'
« Reply #1 on: June 29, 2004, 11:43:37 pm » |
NYD,
Could you post the link to that schematic again?
Thanks, -E
I am just the Web Geek here. All sales/support questions should be directed to Prodigy Professional Sales Staff via the contact page of the main website.
Tekay
Halmstad-Sweden
« Reply #2 on: June 30, 2004, 02:45:56 am » |
The resistor in the "C" position will change the buss impedance when selected! Then the needed make up gain also will change! Will probably work as long as you don't change anything while you're mixing!
I was looking into a passive system too but since I like to be able to insert outboards between the interface and the summing unit. I don't like the idear to feed the outboards with signals at mix levels, better to get as much as possible out of the inteface, then process it and finaly pad them down in 5 dB steps until you reach the right mix level again of each instrument! Then you can make the small changes ( with in the 5dB steps) at your DAW or if it's a compressor it's better to change the outputlevel on the compressor so you don't change the threshold level.
One of the idears is to use as manny of the available bits as possible too! "Just A Thought"
NewYorkDave
New York (Hudson Valley)
« Reply #3 on: June 30, 2004, 12:29:14 pm » |
The resistor in the "C" position will change the buss impedance when selected! Not by much! Then the needed make up gain also will change! That's the whole point of the resistor! The signal should be down -3dB in both busses in the center position, to keep it from getting louder as it's switched from L or R to center! (Why are we using all these exclamation points, anyway? :wink: ). The idea for this particular L-C-R switch arrangement did come from me, in response to a request someone made on the old board. It seemed a more usable arrangement than simply connecting the channel to both busses without any level or impedance compensation, as some designs do. Here's my drawing: http://electronicdave.myhosting.net/miscimages/lcr_switch.gifIf you do the math, you'll see that the impedances looking in both directions do change as the switch is changed, but not enough to upset the driving source nor significantly alter the loss of the mix buss, outside of the desired additional 3dB of attenutation in the "C" position. deArry, your diagram looks fine at a glance. Three positions (L, C, R) wouldn't be enough for my style of mixing; but if one insists on a balanced mix buss, it's tough to find 4-pole switches with many positions. If I were building a summing buss box, I would be inclined toward unbalanced internals with transformer I/O. Then there'd be no need to worry about leakage/noise problems from all that circuitry floating above ground, and the pan control could be made much more versatile, either switched with more steps, or continuously variable. But I do understand that some might want a "resistors only" box with no transformers to color the sound, for better or worse. A friend asked recently about an add-on mixer to implement echo sends on an old ten-channel broadcast board. Here's a sketch I made for him; essentially, it's an unbalanced version of the type of passive mixing network we're talking about here. http://electronicdave.myhosting.net/miscimages/echosendmxr.gif
magicchord
« Reply #4 on: June 30, 2004, 01:28:10 pm » |
If I were making this, I think I'd add a resistor between each side of each mix bus and ground. That would eliminate the possibility that the mix buses would ever be floating and you won't get a big POP when you mute an input.
NewYorkDave
« Reply #5 on: June 30, 2004, 01:58:48 pm » |
Sounds like a good idea to me.
daArry
londaaan
« Reply #6 on: June 30, 2004, 07:58:46 pm » |
I was looking into a passive system too but since I like to be able to insert outboards between the interface and the summing unit... Yes, this is how I was gonna run things...DAW Outs > Patchbay > Outbrd > Summing box > ext pre for any makeup... deArry, your diagram looks fine at a glance. Three positions (L, C, R) wouldn't be enough for my style of mixing; but if one insists on a balanced mix buss, it's tough to find 4-pole switches with many positions. Cool. I've just scored a load of some nice alps 4 pole 6 pos switches so will be using these  If I were making this, I think I'd add a resistor between each side of each mix bus and ground. Was that in regards to what I posted or NYDs' echosendmxr.gif pic? Cheers
NewYorkDave
« Reply #7 on: June 30, 2004, 09:05:36 pm » |
Cool. I've just scored a load of some nice alps 4 pole 6 pos switches so will be using these  I'll come up with an attenuation value for those "in between" positions, if you like. Or if you prefer to do it yourself, I can give you the equations. If I were making this, I think I'd add a resistor between each side of each mix bus and ground.
Cheers That's for the balanced mix buss. The unbalanced mix buss doesn't need it.
daArry
londaaan
« Reply #8 on: June 30, 2004, 09:18:40 pm » |
I'll come up with an attenuation value for those "in between" positions, if you like. Or if you prefer to do it yourself, I can give you the equations. great! if you've come up with the values already...yes i'd like to peep em - save me some head scratchin :roll:
NewYorkDave
« Reply #9 on: July 01, 2004, 04:53:58 pm » |
Here's what I came up with. According to the AES Engineering report "Precision Pan Pots" (Richard C. Cabot, April 1978, Volume 26, Number 4), the attenuation values that correspond to displacement of 25 degrees either side of center are 0.5dB and 9dB. This should give just about as smooth a "pan" as you can expect from only five positions. http://electronicdave.myhosting.net/miscimages/5pospanswitch.gifThe impedance seen by the driving source will vary between 0.7 and 1 * Z. The impedance reflected to the mix buss will vary between R and R + 1.8Z + driving source impedance.
daArry
londaaan
« Reply #10 on: July 01, 2004, 06:20:09 pm » |
Cheers Dave! :grin:
daArry
londaaan
« Reply #11 on: September 27, 2004, 05:18:39 pm » |
Just to confirm, would these resistor values be correct for that there 5pos pan switch (based on 600R Z, 16 chan)
-0.5dB - 360R -03dB - 2K4 -09dB - 10K8
ta
EDIT, i'm shit at maths and need to know if i'm calculating the correct values...
daArry
londaaan
« Reply #12 on: September 28, 2004, 12:40:07 pm » |
have i got shit on me shoe or summin?
NewYorkDave
« Reply #13 on: September 28, 2004, 12:50:53 pm » |
600 * 0.06 = 36 600 * 0.4 = 240 600 * 1.8 = 1080
Remember to halve the values if you're building a balanced network.
daArry
londaaan
« Reply #14 on: September 29, 2004, 07:25:13 am » |
ahh the mixer man commeth  cheers :thumb:
daArry
londaaan
« Reply #15 on: October 19, 2004, 08:37:49 pm » |
finally comin together :thumb: just need to add another 8 chan ontop of those already there!    (the brd to the right is just a JFP gaintstage - box will remain psv tho)
Sleeper
Los Angeles
« Reply #16 on: October 20, 2004, 12:07:28 am » |
Hey DaArry That looks great, are those relays? Whats that wierd blue cable.
Nice One.
Sleeper
clintrubber
The Netherlands
Global Moderator
« Reply #17 on: October 20, 2004, 03:44:27 am » |
Whats that wierd blue cable. Looks like 'remote controlled' switches, right ? Have seen such things been used in older Marantz hi-fi amplifiers (source-select, record-select). Nice system. Last but not least, that box looks :thumb:
mcs
Denmark
« Reply #18 on: October 20, 2004, 08:26:01 am » |
Looks great!
Where can you buy those switches?
Best regards,
Mikkel C. Simonsen
daArry
londaaan
« Reply #19 on: October 20, 2004, 08:28:32 am » |
Looks like 'remote controlled' switches, right ? / Whats that wierd blue cable heh, not that complicated - those are regular switches (4P6Way) for left/center/right control. The cable connects the rotary switch (on one end) to the switch contacts which are housed in that lil ting that looks like a relay...pretty good as the signal is confined to that bak and on that brd  Where can you buy those switches? They are alps switches - marked 905E. Got a load surplus but I think theyre pretty old as theyre not in the alps catalog I have. Guess I could let a few go tho :wink: Cheers! D
