September 09, 2010, 01:42:02 pm *
Pages: 1 [2] 3 4
Author Topic: 438C build questions.  (Read 2604 times)
jensenmann
Karlsruhe, Germany
« Reply #20 on: May 18, 2009, 12:36:45 pm »
Good ideas thanks! What did you pay for your torodial?
Here's the enclosure I'll be using. Old geiger counter, hope it's not radioactive... Shocked
app 40€
Jens
Quote from: "PRR"
>The tubes of course don't care what frequency they distort
eskimo
« Reply #21 on: November 12, 2009, 05:34:59 pm »
Some in progress(after a looong hiatus) pics:
« Last Edit: November 12, 2009, 06:04:54 pm by eskimo » Logged
eskimo
« Reply #22 on: November 14, 2009, 05:09:53 pm »
PSU question:
The values I should be getting in black, the values I am getting in red.
Note:
-The PT secondary gives 128VAC instead of the 117VAC on the original. I assumed that was close enough.
-R21 is 6,8K 5W instead of the 7K on the schem.
-I'd miswired the PT secondary on the first powerup which fed the circuit, 250VAC, can that have messed up the caps? I did hear a weird sissling sound coming from them before I hurried and shut it off.
Any ideas?
Schematic:
http://eskimo.creotia.com/438C.jpg
schmidlin
Ohio
« Reply #23 on: November 15, 2009, 09:41:35 am »
Are these voltages under load, ie with the tubes in it?
perception > reality
eskimo
« Reply #24 on: November 15, 2009, 11:31:28 am »
No, I didn't dare put them in yet, could it be as easy as that?
Kingston
Helsinki, Finland
WWW
« Reply #25 on: November 15, 2009, 12:22:43 pm »
Yes indeed. Ohms law is as easy as that.
eskimo
« Reply #26 on: November 15, 2009, 12:52:23 pm »
doh.  Wink
Well, even with the tubes in the numbers are way off.
From left to right:
299, 209, 330.
eskimo
« Reply #27 on: November 16, 2009, 06:38:39 pm »
badabump
schmidlin
Ohio
« Reply #28 on: November 16, 2009, 10:09:38 pm »
Well, here goes:
Check your heater voltage carefully.  If it close to 6.3, you can bump up R20 & R21 up to get you where you need to be.  If you are getting 7 volts or so, you have several not-very-good options such as a padding your AC-in via power resistors or a variac.  Or get a custom (yikes) PT wound.  My guess is you are suffering from an overly-ambitous home power supply company, common here in the States, too.  Check your wall AC or even question your VOM.
As a side note, your PT being so close to the signal tubes has me wondering if you will get some residual noise from it.  Separation is your friend.
Hope this helps.   Tongue
PRR
Maine USA
« Reply #29 on: November 16, 2009, 11:06:48 pm »
Your power transformer is better than the original. 117VAC peak-doubled should be over 300VDC, not the 255V shown on the original: they used a lame transformer (but good enough).
Put about 500 ohms 1 Watt in between the 117/125V lead and the two-diode point. With load (tubes), this will come down into the 230VDC-280VDC zone. Fiddle the resistor to get closer. It does NOT have to be 255VDC exact: in fact 200VDC or 300VDc would be fine.
« Last Edit: November 16, 2009, 11:13:00 pm by PRR » Logged
eskimo
« Reply #30 on: November 16, 2009, 11:38:34 pm »
Much appreciated!
Did some more measuring.
The wall socket gives me 230V(as expected), the primary is wired for 240V though which explaines why my heaters are a tad low at 5,9VAC.
Thanks for the resistor tip PRR.
Right now it's wired like this:
If I use the Blu/Yel 110V tap instead(or connect brown to black/red instead of black) I should get 230V right? (sorry for the noobness)
PRR
Maine USA
« Reply #31 on: November 16, 2009, 11:45:07 pm »
No big deal, but yes, do this:
eskimo
« Reply #32 on: November 17, 2009, 05:16:07 pm »
So I've gotten a useful mic signal out of the thing. No compression in sight yet though.
I assume I've messed my wiring of the pots(threshold, attack, release).
In P1 and P2, does pin 2 connect to 1 or 3? As for P3, does 1 or 3 go to R15?
PRR
Maine USA
« Reply #33 on: November 17, 2009, 08:52:26 pm »
For smoke-test: either. If it is "wrong", the knob turns "backward", but the limiter still limits.
You could leave the wiper un-connected. That gives long attack long release.
Put the junction of R10 R11 to ground. That gives a threshold of "nothing": any medium-strong signal will make DC on C4 and the input grids.
You'll want control someday, -after- you get it "working".
eskimo
« Reply #34 on: November 23, 2009, 01:36:23 pm »
Tried that but no difference.
I noticed now that if I really slam it, like bass straight through on high gain, I can hear a vague compression. So it seems to do something, but extremely little of it.
eskimo
« Reply #35 on: November 25, 2009, 11:38:26 am »
I installed a VU (well almost, peak signal meter) and it seems to respond well. Reacts to threshold level. Attack and release works as expected. I still can't hear it though. Does that give any clues where the problem might be?
skal1
Birmingham,uk
« Reply #36 on: November 25, 2009, 02:04:20 pm »
Have you checked pin 1 and 6  of the v2  under compression / no compression ?
when under compression pin 1and 6  should rise .
skal1
eskimo
« Reply #37 on: November 25, 2009, 02:17:52 pm »
1 is 60V when idle and 6 is 55V. It's kinda critical that both sides are in balance right?
Anyway, both side go up to 300ishV under full compression.
skal1
Birmingham,uk
« Reply #38 on: November 25, 2009, 04:49:57 pm »
So they say.
Was this v1 or v2 ?
schematic  says  150v on both plate   Huh your readings are low for v2   according to the schematic at idle.
skal1
eskimo
« Reply #39 on: November 25, 2009, 04:54:22 pm »
On V2, V1 is the mic pre front. The schem says 60V, no?
Pages: 1 [2] 3 4
